Creating a drape surface
| Command | Path |
| Create Drape Surface | Model > 3D Power Pack |
You can automatically create a rectangular, draped NURBS surface over an object, up to a specific Z plane value. This is useful for representing surfaces including curtains, tablecloths, product packaging, and (with Vectorworks Architect or Landmark) site models.
To create a drape surface:
Select one or more objects to be draped.
Select the command.
The Create Drape Surface dialog box opens.
| Parameter | Description |
| Number of Points | Specifies the number of control points on the drape surface; the greater the number of points, the closer the drape surface is to the object |
| U Direction | Enter the number of points to create in the U direction; this number must be greater than 3 |
| V Direction | Enter the number of points to create in the V direction; this number must be greater than 3 |
| Plane Z Value | Specify the base level of the drape surface (how far down the bottom of the drape goes), which must be less than the highest Z coordinate of the object |
